Frame Relay Stress Testing
Hi All,
My network has a bouncing frame relay circuit. Every time our link takes a hit, we call the carrier and they would perform a stress test for that bouncing circuit and all they say after the stress test is, "there where no errors found". They told me that they used intrusive and passive tests. I really dont know what these test are, so my questions is,
1) What are the types of test performed on a frame relay circuit?
2) What could be the problem with the bouncing circuit? (Already replaced WAN cable from router to CSU/DSU, router configurations are all good and no extended demarc)
3) What troubleshooting approach should i do to isolate the problem?
Usually after the stress testing, circuit would be up and running pretty well for 2-3days. Then the circuit goes bad again after that. seen lots of crc and input errors on the serial interface btw.
t814687 Fri, 04/25/2008 - 08:01
1) Depends on the equipment they use for FR network, they can do a specific test for PVC and run a loopback test up to a CO.
2) It looks like a local loop issue to me.
Did they ask you to put your router serial interface in a loop state and run a test or you can do some pings?
here is a good reference you can look and start troubleshooting:
