Goutam Sanyal Thu, 04/24/2008 - 23:13
Hi Samtiano,
WIC 2-port asynchronous/synchronous serial WAN interface card is listed for support the said platfrom. URL:http://www.cisco.com/en/US/prod/collateral/routers/ps5853/product_data_sheet0900aecd8016a59b.html
As per Cisco:
The dual-serial port WAN Interface Card (WIC-2A/S) provides higher levels of serial port density for a single WIC and is supported on the Cisco 1700, 2600, and 3600 series. The low serial speed WIC-2A/S supports up to 128 Kbps synchronous or 115.2 Kbps asynchronous serial links. Each port on a WIC is a different physical interface and can support different protocols such as Point-to-Point Protocol (PPP) or Frame Relay and Data Terminal Equipment/Data Communications Equipment (DTE/DCE). This WIC supports mixed asynchronous and synchronous operation on a single card as well.
These dual-serial port WICs feature Cisco's new, compact, Smart Serial connectors to support a wide variety of electrical interfaces when used with the appropriate transition cable. This includes: V.35, RS-232, RS-449, RS-530, RS-530A in male and female versions for both DTE and DCE devices. This feature provides easy configuration and reconfiguration as network requirements change, without the need of purchasing a different serial interface card.
But its not listed with URL:
http://www.cisco.com/warp/public/107/wic-2as.shtml
Thanks Goutam
