1.You must explicitly disable the Call Waiting option on the agent's phone
to successfully use this feature. The Call Waiting option must be
disabled (default) in Unified CM on each Outbound agent phone to ensure
that every customer call successfully transfers to an available agent.
2. When the campaign is started, the system should check for available
agents, and then select an agent by placing the agent in the "Reserved"
state. The agent should receive a pop-up window w\ the customers info in
it. Then the agent has the choice to accept or not accept the call,
before the subsytem dials the customer. If the agent accepts, then it
should dial the agents phone first, so he can actually hear the call
being made.
3.So, is the system presenting the customer pop-up window to multiple
agents simultaneously and they all are accepting?
4. Or is one agent receiving the pop-up window and then accepts the
call, but multiple agent phones are simultaneously being connected to
that one call, before \ after the call is initiated to the customer?
5. What is the actual multi-agent call scenario? Provide a few more
details.
