Historical Reports logon error
Apr 25th, 2008
UCCX Version:5.0(1)_Build433
CUCM System version: 6.0.0.9971-2
Client OS:Windows XP Pro Eng edition with SP2
I have given a user access to login Historical Reports tools.
When i logon Historical Reports tools,it pop-up a error window,please see the attachments.
Thanks.
Overall Rating: 4.3 (3 ratings)
mmelbourne Fri, 04/25/2008 - 02:24
Check whether you have a browser proxy exclusion for the UCCX server. The initial authentication is performed over HTTP.
Wei Wang Fri, 04/25/2008 - 07:59
Thanks for you reply.
I do not have a browser proxy in use.
Could you tell me more detail about the initial authentication for UCCX Server?
Thanks.
richb1971 Wed, 05/28/2008 - 08:02
I've got exact same error message. Did you get this resolved?
Rich
Wei Wang Wed, 05/28/2008 - 17:59
Hi,richb1971
I've got this resolved.
Please try edit hrcConfig.ini in your Historical Reports tools installation path.
Changing database Authentication mode in "AUTH=".
richb1971 Wed, 05/28/2008 - 23:27
Hi happy4ever,
After I edit it, save it and run HR it reports same error message and changes it back to AUTH=2!
Any ideas?
Cheers
Rich
richb1971 Wed, 05/28/2008 - 23:36
Scratch that. There are 2 AUTH's! Changed other one and it worked. Cheers happy4ever.
nowhappy4today
:D
Wei Wang Wed, 05/28/2008 - 23:46
Oh,Please changing here in hrConfig.ini.
;AUTH specifies the authentication mode to use while connecting to the database.
;Use one of the following values:
;1 - Windows NT Authentication
;2 - Mixed Mode Authentication
AUTH=1
