Using RisPort WSDL - C# with RISService to make request - HTTP 505 Problem.
Apr 25th, 2008
Well, I decided to use the RisPort WSDL with C#.NET to make my requests.
I still have a HTTP 505 ERROR (Bad HTTP Version).
Here is my code :
List<String> listeNoeud = new List<string> { };
ServicePointManager.ServerCertificateValidationCallback += delegate { return true; };
ServicePointManager.Expect100Continue = false;
RISService wsRis = new RISService();
wsRis.Credentials = new NetworkCredential(Login, Password);
wsRis.SoapVersion = System.Web.Services.Protocols.SoapProtocolVersion.Soap11;
wsRis.Url = @"https://" + Host + ":" + Port + "/realtimeservice/services/RisPort";
CmSelectionCriteria filtre = new CmSelectionCriteria();
filtre.MaxReturnedDevices = 20;
filtre.Class = DeviceClass.Phone.ToString();
filtre.Model = 255; //"Any" Model.
String stateInfo = null; // Execution summary
SelectCmDeviceResult result = wsRis.SelectCmDevice(ref stateInfo, filtre);
CmNode[] nodes = result.CmNodes;
CmDevice[] devices = nodes[0].CmDevices;
foreach (CmDevice device in devices)
listeNoeud.Add(device.LoginUserId);
return listeNoeud;
How could I use the HTTP VERSION 1.0 ? Where do I need to specify it ?
Config :
Call Manager 6.0.
Visual Studio 2008.
stephane.lhp Fri, 04/25/2008 - 03:32
Here is the result of SNIFFING with WIRESHARK :
POST /realtimeservice/services/RisPort HTTP/1.1
User-Agent: Mozilla/4.0 (compatible; MSIE 6.0; MS Web Services Client Protocol 2.0.50727.1433)
VsDebuggerCausalityData: uIDoo44LS9aWDclCg356m9lojzEBBBBBU4GjxicVUkeMySxHTpRd7F3UXpR10IxAn6h5VQI7Cl0ACQAA
Content-Type: text/xml; charset=utf-8
SOAPAction: "http://schemas.cisco.com/ast/soap/action/#RisPort#SelectCmDevice"
Host: 10.1.1.100:8443
Content-Length: 1015
Connection: Keep-Alive
<?xml version="1.0" encoding="utf-8"?>http://schemas.xmlsoap.org/soap/envelope/" xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/" xmlns:tns="http://schemas.cisco.com/ast/soap/" xmlns:types="http://schemas.cisco.com/ast/soap/encodedTypes" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">SessionIdhttp://schemas.xmlsoap.org/soap/encoding/">4294967295Phone255
The problem is the FIRST line :
How could I modify this header ?
How could I change HTTP/1.1 by HTTP/1.0 ??
Thanks in advance, I'm still stuck.
stephane.lhp Fri, 04/25/2008 - 06:08
Could you find me an answer to this ambiguous problem ???
I just use Cisco RisPort WSDL, with RISService object, and this object is not compatible with Cisco RisPort web service ... (because of HTTP 505 Error : Http Version not compatible, and I don't know how to change it to 1.0).
What's the problem ?
Vlad Polyakov Mon, 03/02/2015 - 12:19
I doubt that the problem is current for its author ( it's been 7 years now), but here is what actually happens in C#:
  1. There is no need to change HTTP protocol version
  2. Leave SOAP version to default (wsRis.SoapVersion = System.Web.Services.Protocols.SoapProtocolVersion.Soap11; is not needed and it in fact triggers HTTP error).
  3. Avoid using filtre.Class = DeviceClass.Any.ToString(); Actually, that enum, when auto generated from WSDL, does not contain all types (I had to manually alter the DeviceClass and add a   HuntList member
