Use of "switchport access mode"
Apr 25th, 2008
I have a 2960 switch with 2 vlans as 10 & 20.
ports from f0/1 to f0/10 belog to 10 vlan and from f0/11 to f0/23 belog to 20 vlan.
f0/24 is a trunk port
PCs connected to this switch get dhcp ips from a dhcp server(1841 router).
sample config of 2 switch ports of 2 vlans
interface f0/1
switchport access vlan 10
switchport mode access
interface f0/11
switchport access vlan 20
My question is, the pcs get ips even without "switchport mode access"
The setup works even without that command line.
I understand that "switchport mode access" set the port into a access port.
But if the above set up works without that what is the real necessity of this command line. please explain.
spremkumar Fri, 04/25/2008 - 02:51
hi
hope this helps
switchport access : Set the port to access mode (either static-access or dynamic-access depending on the setting of the switchport access vlan interface configuration command). The port is set to access unconditionally and operates as a nontrunking, single VLAN interface that sends and receives nonencapsulated (non-tagged) frames. An access port can be assigned to only one VLAN.
regds
