Broadcast SSID's
Apr 25th, 2008
Can anyone advise on my wireless set up.
I have 3 Wireless VLAN's is it possible to broadcast 2 of the SSID's for public access(so that they show when you search) and keep one as a hidden SSID.
SJessulat_2 Fri, 04/25/2008 - 02:46
Yes, this is possible.
For autonomuous IOS Access Points, look under Security -> SSID Manager. At the bottom of the page you have to activate "Multiple BSSID" and for every SSID you want to broadcast click "Set SSID as Guest mode".
For LWAPP Access Points, look under WLANS -> and click "Broadcast SSID".
