How to stop verification of command
Apr 25th, 2008
When I run "copy run start" the IOS always prompts me with "Destination filename [startup-config]?", is there a way to stop this prompt while still using the copy command?
Dan
Overall Rating: 4.5 (2 ratings)
Richard Burts Fri, 04/25/2008 - 07:39
Dan
I can not tell you how to stop that prompt but I can suggest a way to work around it. Instead of using copy run start try using the old write memory. This command does the same thing and does not have the verification prompt.
Rick
Richard Burts Fri, 04/25/2008 - 10:45
John
This is more directly what was asked about. Better than my workaround. Rated as deserved.
Rick
