04-25-2008 04:25 AM - edited 03-03-2019 09:42 PM
i am having problem with OSPF.
I have a network of 150 Branch router.
all these branches are available thorugh my fast ethernet interface (my media is MPLS).
i am migrating my network to DMVPN with OSPF, before this i was using GRE tunnel with static routes.
I have migrated 60 routers on it.
all of the are in area 1
when i see show ip ospf nei
I see 7-8 neighbour routers are stuck in exstart state.
i couldn't under stand whats the problem
i have also put ip ospf mtu-ignore.
set the mtu to 1400 on tunnel interface.
Can anybody please help.
Atif
04-25-2008 06:50 AM
Can u pls. provide a sho run for OS config on core & edge routers?
Thx.
Mo
04-25-2008 08:55 PM
core 3845 HSEC adv IP services 12.4(3e)
Branches 2801/11 adv security 12.4(3H)
Core Router:
crypto isakmp policy 10
hash md5
authentication pre-share
crypto isakmp key ni135 address 0.0.0.0 0.0.0.0
crypto ipsec transform-set NI_Sec_DMVPN esp-3des esp-md5-hmac
crypto ipsec profile NI_DMVPN
set security-association lifetime seconds 120
set transform-set NI_Sec_DMVPN
interface Tunnel0
ip address 172.30.0.1 255.255.240.0
no ip redirects
ip ospf mtu-ignore
ip mtu 1400
ip nhrp authentication ni135
ip nhrp map multicast dynamic
ip nhrp network-id 1
ip ospf network broadcast
tunnel source 192.168.220.146
tunnel mode gre multipoint
tunnel key 0
tunnel protection ipsec profile NI_DMVPN
router ospf 1
network 10.200.0.0 0.0.3.255 area 0
network 172.30.0.0 0.0.15.255 area 2
area 2 stub no-summary
Branch Router
hash md5
interface Tunnel0
ip address 172.30.3.224 255.255.240.0
no ip redirects
ip ospf mtu-ignore
ip mtu 1400
ip nhrp map 172.30.0.1 192.168.220.146
ip nhrp map multicast 192.168.220.146
ip nhrp nhs 172.30.0.1
tunnel source 192.168.220.198
tunnel destination 192.168.220.146
tunnel key 0
router ospf 1
network 10.203.224.0 0.0.3.255 area 2
distribute-list prefix filter_all_except_default in
ip prefix-list filter_all_except_default seq 5 deny 0.0.0.0/1 le 32
ip prefix-list filter_all_except_default seq 10 permit 0.0.0.0/0
04-25-2008 08:30 AM
Did you try 'debug ip ospf adj'.
Thanks.
04-25-2008 10:27 AM
Atif:
If you want to continue troubleshooting on this MTU track, you can try this:
Try applying the ip tcp adjust-mss 1436 command under the GRE interface at both ends. What this does is allow each side to advertise (not negotiate) the maximum size of the data portion of the TCP segment that each will accept.
And then configure the ip mtu setting under the GRE interface at both ends to 1500.
These numbers aren't arbitrary. If you add the TCP header of 20 bytes and the IP header of 20 bytes, plus the GRE header overhead of 24 bytes to the TCP segment size of 1436, the resulting IP datagram will be 1500 bytes in length.
Apply these numbers and come back and tell us if the problem has gotten any better.
Victor
04-25-2008 08:29 PM
Thank victor
One or two thing i like to add before apply the setting
you didn't take account of IPsec overhead.
Further one more info, when the branches are under 50 every thing is normal but when i add more branches like i take it to 65 branches branches get stuck.
Atif
04-26-2008 12:07 AM
I think as per cisco recomendation the number of routers in an area should not be more than 50.
Mahmood
04-26-2008 06:35 AM
Atif:
You're right.
The size of the IPSec header will differ, depending on whether you deploy AH or ESP and whether you use IPSec Tunnel mode or Transport mode. Transport mode is commonly used is GRE over IPSec implementations because the tunnel endpoints are also the same as the IPSec encrytpion endpoints, and transport mode saves about 20 bytes.
So, make the adjustments to the tcp mass accordingly.
Victor
04-26-2008 06:53 AM
Atif:
Forgot to address your second issue.
"Further one more info, when the branches are under 50 every thing is normal but when i add more branches like i take it to 65 branches branches get stuck."
If you have 50 routers working and they are all configured in the same manner (MTU, mass, etc), then I would guess that the 7 or 8 stragglers are having a different issue.
You're going to have to investigate the memory and processor capabilities of your hub router and whether your design is feasible.
Victor
04-27-2008 08:36 PM
12-12-2008 01:59 AM
Dear Atif, i am facing the same issue, did you find the solution to your problem ?
kindly let me know
