LMS3.0.1 DFM Questioned STATE (AGAIN)
Well here we go again. I don't know what happened but all 600+ devices are back in questioned state. I have tried to rediscover and delete/rediscover but that has had no effect. Sticks at 40% for a while then back to questioned. I have heard rumours of a patch?? If this is true I would love to get my hands on it since my boss is looking to use this product for paging and notification.
Please let me know what I should be doing to keep this product stable.
thanks
tony
dionjiles Fri, 04/25/2008 - 05:35
I have that same issue as well. Ever since I upgraded to the LMS 3.0.1 this is an ongoing issue for me.
Joe Clarke Fri, 04/25/2008 - 12:10
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There is a class file available from the TAC (DFMInchargeSubscriber.class) which has been known to fix this problem in some cases. The patch is still experimental, so your results may vary.
As a workaround, disabling rediscovery in DFM should keep the devices known.
Joe Clarke Tue, 06/17/2008 - 07:20
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The DLL patch is part of DFM 3.0.3 and has no bearing on the Questioned problem. There is a DFMInChargeSubscriber.class that should fix this problem. That patch will be part of DFM 3.1.
