04-25-2008 05:55 AM
I've recently set up DFM to alert me on interface utilization problems. One annoying alert I've been getting is a high broadcast rate. Does DFM consider multicast traffic broadcasts? I keep getting high broadcast rates on our L3 etherchannel interfaces interconnecting our switches...but we use multicast very heavily so it's expected. I ran a sniffer just incase and saw that most of the traffic is multicast (and very very little is actually broadcast, which is what I'd expect on a L3 connection)...is there any way to have it distinguish multicasts from broadcasts? I would obviously like to know when there is too much broadcasting going on, but I don't need to get alerted every time multicast traffic goes over a certain threshold.
Solved! Go to Solution.
04-25-2008 08:06 AM
DFM uses if{In,Out}NUcastPkts to obtain the "broadcast" traffic rate. As you pointed out, this object also counts multicast packets. The only workaround for this problem is to increase the threshold, or create an event set which excludes this event.
04-25-2008 08:06 AM
