SUP720-3B memory upgrade
didyap Fri, 05/02/2008 - 11:07
Two 1-GB DRAM DIMMs (to be installed on the Supervisor Engine 720 switch processor and route processor) PFC3BXL only So, looks that you can use 1GB Dimm only WS-SUP720-3BXL supervisors. Because there are switch processor (SP) and route processor (RP) memory on the Supervisor Engine 720.
In WS-SUP720-3B could be 1Gb memory if you use 512Mb - 512Mb each on SP and RP.
Here is the URL which will help you for the SUP720-3B memory upgrade.
