inbound calls divert for whole site/region/dp
Apr 25th, 2008
was wondering if anyone knows a solution for this, what i'm thinking about is; we have our remote sites set up for their own Device Pool and Region as a general rule. What i'd like to be able to do, is in the event of a problem at that site, divert all incoming calls meant for extensions based there, to another site, or annoucement etc. As the main common factor for extensions on a per site basis is Device Pool or region, can anyone think of a way of globally diverting based on this?
Its a Friday afternoon question!!!
Brandon Buffin Fri, 04/25/2008 - 07:52
  • Purple, 4500 points or more
I don't know of any way to route calls based on device pool or region. If you have distinct DN ranges at these sites, you could use a translation pattern. For example, if site A has DNs 5001-5099, you could create a translation pattern of 50XX and translate any call to that range to another DN. This could also be done with a translation rule on an H.323 gateway.
Hope this helps.
Brandon
iptuser55 Fri, 04/25/2008 - 08:21
  • Silver, 250 points or more
How about the follwing
Translations-The DN`s at the two sites will need something to make then unique - maybe description field.
Normal Op - Dial the DN at Site B the call is routed as an internal call. what you want to do is to route the call out via PSTN
Create 2 x Partition called PSTN_TO_SITE_B , WAN_DOWN....
Create a TP for the DN`s at Site B and translate them to their PSTN
Site B extension 45xx- Normal DDI 121055545xx
Add a TP 45xx
Partition "PSTN_TO_SITE_B......"
Add a translation to 121055545xx
Ensure that no-one has either Partition in their CSS so it is not active
Use BAT to identify Site B users via the description I mentioned
Modify only Site B users normal Partition and change then to WAN_DOWN........,
Now change the Partition in the newly created TP for 45xx to the partition you normal assigned to Site B users
Now when Site A users dial the 45xx extension which points to the new TP and is translated to Site B`s DDI
