NAT Timeouts with Cisco Firewall
Apr 25th, 2008
Hi all,
I am having NAT timeouts on a cisco FWSM. Connections to NATed servers timeout after a while. When I use the 'clear xlate' command, it is stable for a while , then the timeouts begin again.
Please kindly assist
rkalia1 Fri, 04/25/2008 - 10:08
Check if you have any embryonic limits or max-conn limits set in the rules on the firewall. You may be going over the limit. Either remove the limits or increase.
