cm423 change hunt group members
Apr 25th, 2008
needing to change dn for hunt group. cannot change dn on phone because field is not changeable, therefore, cannot assign to hunt group. cannot add manually, get msg dn not in partition. any thoughts on why I cannot change dn on phone? thanks
Jaime Valencia Fri, 04/25/2008 - 12:23
are you selecting the member from the hunt group and it's not letting you change it?
If you add it and then move it to the right position? does that work?
you do need to select the proper partition for the DN, if the DN is not in the partition you selected you get that message.
are you using a read-only MLA account??
javalenc
if this helps, please rate
