increase voice volume in a PRI interface
connect101
I want to increase the output volume of my voice ports.
How can I do?
I don't know realy how to use the
"output attenuation"
and the "input gain".
In which case I will use the first, and when I will use the second?
Thank you
Brandon Buffin
If you're having a problem with volume for outgoing calls, it could be a problem with the PRI configuration. Can you post the output of "show controllers T1"?
Brandon
I Think my configuration is correct but i give the result here :
E1 0/0/0 is up.
Applique type is Channelized E1 - balanced
Description: voix
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20070320, FPGA: 20, spm_count = 0
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (458 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
E1 0/0/1 is up.
Description: Second Ligne Voix
No alarms detected.
Data in current interval (459 seconds elapsed):
E1 0/2/0 is up.
Description: 3e E1
No alarms detected.
Data in current interval (464 seconds elapsed):
E1 0/2/1 is up.
Description: 4e E1
No alarms detected.
Data in current interval (465 seconds elapsed):
connect101
My second problem is that the called person hear a little echo.
This is the port configuration :
voice-port 0/0/0:15
echo-cancel coverage 32
echo-cancel mode 2
cptone FR
description VOICEPORT PSTN 2
bearer-cap Speech
