Using Kron for Reload
Apr 25th, 2008
I have been unable to schedule recurring reloads on my WAN routers. Any suggestions are very much appreciated:
kron occurrence RELOAD at 00:01 Fri recurring
policy-list RELOAD
kron policy-list RELOAD
cli reload
after running, the router drops cli reload command.
t814687 Fri, 04/25/2008 - 09:55
Keep in mind this: "EXEC commands that generate a prompt or can be terminated using keystrokes will result in an error on execution"
I do not remember if the router asks you to confirm the reload but I suspect it is.
scott.hartlaub Fri, 04/25/2008 - 10:00
Thanks. It does ask to confirm, and i figured that was the problem. I was hopeful there was a work around. Thanks again.
t814687 Fri, 04/25/2008 - 10:00
...maybe your startup config was not saved and router prompts for 'confirm' ?
blittrell Thu, 01/29/2009 - 07:44
Sorry, the suggestion I had won't work either, just edited this to remove my idea:(
