IP Phone Dial Streaming Audio
Apr 25th, 2008
I am installing a CM6.0 and Unity Connection at a Public Safety Center. The Police Dept has asked if there was a way for the IP Phones to dial a number and listen to the live audio stream of a scanner. The patrolmen are having difficulty receiving a good scanner signal on their portable units inside the building.
ROBBY HARRELL Fri, 04/25/2008 - 13:32
They want to be able to listen to a live audio feed by dialing and extension on their, or by a service. It would be like background music on some other phone systems.
I had told them that another option would be to load audio streaming server software on a PC, connect their scanner to the sound card input, and use their PCs to listen to the audio. But they would rather have it through the phones, if possible.
