Restrict Bandwidth
Apr 25th, 2008
Hi, I know that Cisco ASA has limited QOS but is there any other way so that I restrict bandwidth usage on users and allocate bandwidth as per user requirements. I have 1mbps lease line link and when users download anything through internet then network gets slow and all users suffers so I want to allocate only 20 kb to each user, means each user will able to use upto 20 kb not higher than 20 kb. Thnaks
Overall Rating: 5 (3 ratings)
rkalia1 Fri, 04/25/2008 - 10:05
You can use MQC to rate-limit (Policing) the traffic and apply the service-Policy on the outside inetrface. Release 7.x and later provides this feature of rate limiting.
ray_stone Fri, 04/25/2008 - 10:09
Hi Thanks. Is there any example of MQC configuration so that it would be easy for me to configure. Thanks
BrinksArgentina Mon, 05/12/2008 - 05:36
I recently use this conf to limit bandwidth used by internal users conecting to an external terminal server.
access-list acl_QoS extended permit tcp any any eq 3389
class-map class_QoS
match access-list acl_QoS
policy-map outside_policy
class class_ QoS
police output 56000 1500
service-policy outside_policy interface outside
I can see that ASA restrict no tonly outgoing but returning traffic matched by this ACL.
