Load balancing for remote sites with dynamic IPs
Apr 25th, 2008
My site router is connected to 2 remote routers thru Internet. Any ideas how can I set load balancing up if remote sites get their ip addresses from ISP's DHCP server?
joseph.yuffa Sat, 04/26/2008 - 08:52
The example is not relevant to my case. Please see attached diagram for my topology. I need load sharing between destination routers B and C when accessing it from A
paolo bevilacqua Sat, 04/26/2008 - 09:44
  • Hall of Fame,
    Founding Member
Sorry, can't see proprietary file format.
The remote router will have to begin the vpn via a dmvpn type setup.
You can also no not envrypt and just use poin-to-multipoint GRE with nhpr. This is also a DMVPN tecnique.
Then when you have routing information for the site over GRE tunnels, router will load share using the two lthat you will have set to be terminated at B and C. With dynamic routing, you will have redundancy as well.
