SIP username to number issue.
Apr 25th, 2008
I have a little problem I'm trying to work out. I've registered CME to a voip provider using the username of the account, not a number. The problem I'm having is that incoming calls use the username in the SIP URI and not my number. Is there is a way to translate the username to a number so that CME can route the call to the phone?
Paolo Bevilacqua Sat, 04/26/2008 - 03:09
Hi, you should really ask ITSP to provide a called number to you. Tha is the way telephony (including voip) universally works.
colin.flanagan Sat, 04/26/2008 - 20:42
You should be able to ask your provider send DNS with the SIP string which CME pick's up to your inbound dial peer or translation pattern .
