Monitoring BGP using SNMP
Apr 26th, 2008
Hi Friends,
We have BGP enabled on our networks with SNMP enabled to trigger alerts in case of link up/ downs. What we observe is when BGP session goes Active (but interface is up), we do not get any alert from SNMP saying BGP status has changed. The SNMP configuration is as below. Would appreciate if you can let me know if there is anything missing or something required to the config to monitor BGP state changes. Thanks in advance.
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps isdn call-information
snmp-server enable traps bgp
snmp-server enable traps config
snmp-server enable traps frame-relay multilink bundle-mismatch
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps syslog
Best Regards,
cisco_lad2004 Sat, 04/26/2008 - 02:11
Your config looks fine, so what I can think of now is MIB not loaded in you monitoring platform.
howver I cannot see if you are actually sending your traps tou your platform "snmp-server host x.x.x.x"
1-When BGP is active, do you actually see it in router log ?
2-if traps is not sent or received a poll should show you have lost BGP.
3- of all above fails, you could try enabling informs instead of traps.
Manoj Wadhwa Sat, 04/26/2008 - 04:04
Hi Sam,
We are using HPOV & Concord for monitoring. SNMP Host is already defined and we are getting the normal link up/ down alerts. However, I would like to know if there is any way in which BGP state changes can be tracked. I checked in the router logs and dont find any logs if BGP flaps/ goes down even though level 7 logging has been enabled for buffer (logging buffered 16384 debugging). Can you please let me know how informs would help? In case you have any document that explains this, please do share. Thanks!
Best Regards,
cisco_lad2004 Sat, 04/26/2008 - 04:14
informs are more reliable than traps. but if you are not seeing logs in router itself then informs wont help as the issue is the router.
configure "bgp log-neighbor-changes" under bgp process this will solve ur issue.
