Port channel
Apr 26th, 2008
need some one help on port channel.
I was trying to trace a server port with a mac ex aa:bb:cc:dd:ee:ff
and from the switch i got the entry as
Switch (enable) sh cam aa:bb:cc:dd:ee:ff
* = Static Entry. + = Permanent Entry. # = System Entry. R = Router Entry.
X = Port Security Entry $ = Dot1x Security Entry
VLAN Dest MAC/Route Des [CoS] Destination Ports or VCs / [Protocol Type]
529 aa:bb:cc:dd:ee:ff 6/10,7/20,8/3,9/22 [ALL]
Shows that this are 4 ports to form the port channle 6/10,7/2
But how do i know amoung this which one is phyiscaly connected to server NIC ./
I am trying to trace the switch port for the server nic
mahmoodmkl Sat, 04/26/2008 - 03:30
Is the port channel configured between the switch and the server or there is a switch at the other end.If there is a switch at the other end u need to log in that switch and check for the mac-address.if not then u need to log into the server and check the mac-address assinged to each network interface.
jaleel.mohd Mon, 04/28/2008 - 21:29
Thanks for yor respone.is there any way we can configure the port channel directly to servers
so if i understand. 4 NIC or server connected to 4 ports on switch ?
Please let me
Thanks in Advance
mahmoodmkl Mon, 04/28/2008 - 22:01
U can use upto 8 ports on switch to form a channel.On the server side u need to use teaming.
