ASA 5520 : IP address for CSC SSM
Apr 26th, 2008
Hi All,
I have an ASA 5520 with CSC SSM. I have base and plus license and want to activate it. T he IP address and gateway have to be configured on the CSC SSM. I have configured IP addresses for the INSIDE,OUTSIDE,DMZ and MGMT. The outside is a public IP address. Now for the CSC SSM what range should i give?
There is an ISA server on the DMZ where all user IP's get PATed and on ASA this gets NATed on the ASA. Direct access to the internet exists for the servers (bypassing proxy).
My basic doubt is about the IP address and gateway that the CSC SSM should have and is it related ot the management interface ip address?
Thanks and Regards.
smohanasundaram Fri, 05/02/2008 - 02:19
put your CSC ip address as outside interface subnet.because CSC needs automatic updates from internet.and you can able to manage CSC from remote itself.
for EX
your outside ip is,make CSC IP As,Gateway
Hopes this helps
S.Mohana sundaram
