Help, TCL AA Running me MAD!!!!
Ayodeji Okanlawon
I am tryin to deploy TCL aa in my lab and Im running berzerk now!!!!
My config and debug voice application script are show below:
BR1#sh run | b application
application
service aa flash:app-b-acd-aa-2.1.0.0.tcl
param max-time-call-retry 60
param voice-mail 2070
paramspace english index 0
param service-name cme
param handoff-string aa
paramspace english language en
param number-of-huntgrps 3
param max-time-vm-retry 1
param aa-pilot 4003
paramspace english location flash:
param second-greeting-time 30
paramspace english prefix en
param call-retry-timer 20
dial-peer voice 120 voip
service aa
destination-pattern 4003
session target ipv4:10.12.1.254
incoming called-number 5003
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
*Mar 1 00:06:45.671:
*Mar 1 00:06:45.679: //2//TCL :/tcl_PutsObjCmd: TCL AA: +++ B-ACD-SERVICE not r
egistered, Starting B-ACD-SERVICE +++
proc init_perCallvars
*Mar 1 00:06:45.703: //2//TCL :/tcl_PutsObjCmd:
*Mar 1 00:06:45.703: //2//TCL :/tcl_PutsObjCmd: TCL AA: +++ B-ACD-SERVICE not r
*Mar 1 00:06:45.775: //2//TCL :/tcl_PutsObjCmd:
*Mar 1 00:06:45.783:
*Mar 1 00:06:45.799: //2//TCL :/tcl_PutsObjCmd: TCL AA: +++ B-ACD-SERVICE not r
*Mar 1 00:06:45.827: //2//TCL :/tcl_PutsObjCmd:
*Mar 1 00:06:45.831:
*Mar 1 00:06:45.839: //2//TCL :/tcl_PutsObjCmd: TCL AA: +++ B-ACD-SERVICE not r
*Mar 1 00:06:45.839: //2//AFW_:/AFW_FSM_Drive: Tcl_Eval to drive FSM inside Tcl
modulespace. code=1 code=ERROR
*Mar 1 00:06:45.839: TCL script failure
Result:
Handoff Failed
*Mar 1 00:06:45.839: TCL script failure errorInfo:
Handoff Failed
while executing
"handoff appl leg_incoming $serviceName -s $hString"
(procedure "act_Setup" line 30)
invoked from within
"act_Setup"
(procedure "act_Handoff_Activity" line 7)
invoked from within
After I had no succes with this, I downloaded Paolo's tcl script and below is the error is I get on this one too
BR2(config-dial-peer)#
Mar 1 00:06:11.715: %CALL_CONTROL-6-APP_NOT_FOUND: Application aa in dial-peer
120 not found. Handing callid 4 to the alternate app .
application
service aa flash:app-b-acd-aa-2.1.2.2-pl2.tcl
param aa-pilot 4003
service aa
incoming called-number 4003
codec g711ulaw
no vad
For some bizzare reason it says it cant find application aa whihc is defined under service aa.
I have spent hours going through posts on similar things her and now i give up!
Help!!!!
Please rate all useful posts
You're using the wrong file for queue service, the one you want doesn't have "aa" in the name, from the same archive.
paolo bevilacqua
Hi, you have not configured the queue service, that you're referring as "cme".
That is, the other TCL file (two files plus prompts make a complete B-ACD/AA install). Check the documentation again, there are many examples.
Paolo,
I have added the service command and I still get the same error...
see config and debug..
BR2#sh run | b application
application
param aa-pilot 5003
service cme app-b-acd-aa-2.1.2.2-pl2.tcl
param queue-len 10
param aa-hunt1 6400
param number-of-hunt-grps 1
param queue-manager-debugs 1
service aa
destination-pattern 5003
codec g711ulaw
no vad
Mar 1 05:05:55.772: %CALL_CONTROL-6-APP_NOT_FOUND: Application aa in dial-peer
120 not found. Handing callid 8 to the alternate app .
timeouts interdigit 7
BR2#
BR2#debug voi
BR2#debug voic
BR2#debug voice apll
BR2#debug voice app
BR2#debug voice application sc
BR2#debug voice application script
voip application script debugging is on
BR2#
BR2#
Mar 1 05:06:40.789: %CALL_CONTROL-6-APP_NOT_FOUND: Application aa in dial-peer
120 not found. Handing callid 9 to the alternate app .
I have been misled by ieexpert and iementor's solution to this.
When I went back to my books my eyes were opend.
Thank you
