BRI to the same remote router
Apr 26th, 2008
I have 2 BRI(2*64Kbps)=256Kbps to the same remote router. Also i have 2 phonenumber for each one. What do you think i should do in order to have a clear 256Kbps for the remote router and via verca.
Thanks a lot
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Sat, 04/26/2008 - 09:39
Just place all interfaces under same dialer with mlppp and the router will open and close channels as trafic requires.
Search "isdn mlppp" on CCO.
