WLC 2106 Configuration steps
Apr 26th, 2008
I have WLC 2106,And 5 LWAP, 3 Cat3560 Switches.and my 2851 CME router providing DHCP for Data VLAN 1 nad Voice VLAN 100
any one can please help me how to do the basic configuration
when i configure Managment and AP manager on WLC 2106 on untaged VLAN 0 i can able to ping but when i cahnged the VLAN to 1 im not able to communicate to WLC from switch or any port from WLC
please help me to configure the WLC
Thanks & Regards
PRajoth
Overall Rating: 4 (2 ratings)
prajothpj Tue, 04/29/2008 - 04:03
I have this environment:
Router 2851 CME
3 Switches 3560
VLAN 1. 192.168.1.X (Native) Data
VLAN 100. 10.10.10.X (Voice)
VLAN 60 , 172.16.1.X (WLC)
I set WLC with this IP addresses
management 172.16.1.5
ap-manager 172.16.1.6
After basic configuration if I changed the native VLAN (untagged 0) to 60 (tagged) on WLC then I will lose the connectivity from WLC ,and even I was not able to connect from the network.
My switch configuration for WLC
Port mode trunk
Switch port trunk allowed vlan 1,60 ,100
Switch configuration for APS
Port mode Access
Switch port access Vlan 60
Can you please help me
Thanks & Regards
Prajoth
prajothpj Tue, 04/29/2008 - 04:13
my switch port has configured as trunk witch connected to WLC and it was on native VLAN 1 (untaged) but my WLC Port is VLAN 0 (Untaged) , so i changed VLAN on both side to VLAN 60 and on Cisco Switch i say to allow VLANs 60,1,100.
My native VLAN on Cisco Switch still is VLAN1 , i think here i need to change the VLAN to 60 and allow 1 & 100.
please advise me .
Prajoth
The software guide states "A zero value for the VLAN identifier (on the Controller > Interfaces page) means that the interface is untagged.
The default (untagged) native VLAN on Cisco switches is VLAN 1. When controller interfaces are configured as tagged (meaning that the VLAN identifier is set to a non-zero value), the VLAN must be allowed on the 802.1Q trunk configuration on the neighbor switch and not be the native untagged VLAN.
Cisco recommends that only tagged VLANs be used on the controller. You should also allow only relevant VLANs on the neighbor switch's 802.1Q trunk connections to controller ports. All other VLANs should be disallowed or pruned in the switch port trunk configuration. This practice is extremely important for optimal performance of the controller.
Note Cisco recommends that you assign one set of VLANs for WLANs and a different set of VLANs for management interfaces to ensure that controllers properly route VLAN traffic"
Can you supply a screen shot of the interfaces page from your WLC and supply the WLC switch port configuration also? Just to sanity check what you have so far?
ASF_SVI_ITE Tue, 05/06/2008 - 23:10
Good morning! I have read this message and i have to say that I have the same problem. Can I ask if is it a version IOS problem? Can I need a 4.2 version? Actually my controller is working with a 4.1
I have followed on details the configuration that you suggest, andrew, but it seems that putting a VLAN tag for management and AP-management interfaces stops the controller working.
Thanking in advance for your possible help
best regards
Alberto
ASF_SVI_ITE Wed, 05/07/2008 - 01:24
Andrew,
I have set the same VLAN for management and AP-management interfaces. The port of controller is connecting with a trunk port. And I'm allowing those vlans on the trunk.
I repeat: can it depend on the controller IOS release?
Anyway, many thanks for your answer
Best regards
Alberto
ASF_SVI_ITE Wed, 05/07/2008 - 04:34
Hi Andrea. I have solved the problem. It was just the release. I have installed la release 5.0.148 and now all is working (management and AP management interfaces are on a specific VLAN, in my case la 2).
Many thanks for attention. I hope that our dialog can help other indian friend
Best regards
Alberto
Scott Fella Wed, 05/07/2008 - 17:15
Hope you don't run into issues with 5.0.148..... In my opinion, it isn't a very good code...
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
