6500 booting in ROMMON mode
Apr 27th, 2008
Dear Friends,
I am getting memory parity error as seen from sh ver output. The 6500 rebooted suddenly at rommon prompt. When i boot it manually from rommon prompt and execute sh ver once the IOS is booted, i get the following output:
sh ver
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF5, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Sat 08-Jul-06 03:22 by kellythw
Image text-base: 0x40101040, data-base: 0x42D88000
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF5, RELEASE SOFTWARE (fc3)
QFC-Core-2 uptime is 21 hours, 55 minutes
Time since QFC-Core-2 switched to active is 21 hours, 54 minutes
System returned to ROM by s/w reset (SP by processor memory parity error at PC 0x402CD584, address 0x0)
System restarted at 10:56:20 GMT Sat Apr 26 2008
System image file is "sup-bootflash:s72033-ipservicesk9-mz.122-18.SXF5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C6509-E (R7000) processor (revision 1.2) with 458720K/65536K bytes of memory.
Processor board ID SMC102400CZ
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
27 Virtual Ethernet/IEEE 802.3 interfaces
146 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
I see links that pertain to MSFC/MSFC2 in the following URL:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008072c406.shtml#msfc_sub_3
But the customer has Sup 720 (MSFC3/PFC3).
Can someone help me on this please?
Thanks a lot for your time and attention
Gautam
With a memory parity error you can try to clear the hardware by pulling the Sup out of the slot and letting it sit a minute. If the problem persists you really need to open a tac case to get the thing RMA'd. With hardware errors like that you really should call TAC anyway.
