Question about cold start
Answered Question
Apr 27th, 2008
I believe cold start is the router shut down then power back up.
How come the result from show ver said router had been reload instead of power on?
router1 uptime is 2 days, 16 hours, 55 minutes
System returned to ROM by reload at 23:30:12 CDT Thu Apr 24 2008
Correct Answer by mohammedmahmoud about 8 years 11 months ago
When you reload the router using the reload command this is also called a cold restart and the show version shows "System returned to ROM by reload", please check the below document for further details about cold and warm reload:
http://www.cisco.com/en/US/technologies/tk869/tk769/technologies_white_paper0900aecd801778e8.html
BR,
Mohammed Mahmoud.
Overall Rating: 5 (1 ratings)
padramas Sun, 04/27/2008 - 15:40
  • Cisco Employee,
Hello Johnson,
It seems that the router is reloaded by the
"reload" command.
It would display as " returned to ROM by power on " when there is complete power shutdown to router which is a cold start.
Padmanabhan
Correct Answer
mohammedmahmoud Sun, 04/27/2008 - 15:41
  • Green, 3000 points or more
BR,
Mohammed Mahmoud.
