Bidirectional L2L VPN tunnel PIX515E 6.3(5)
Answered Question
Apr 27th, 2008
I have 5 different tunnels running on pix that are one way only meaning we initiate traffic to bring up the tunnels.
I need to create another tunnel but a bidirectional one, that either end can send interesting traffic to bring the tunnel up. Is there a specific command in 6.3.5 code that would allow me to tell the tunnel that is not only an initiator but also a responder, if not could this be done through the crypto acl for the specific tunnel?
Jorge
Correct Answer by Jon Marshall about 8 years 10 months ago
Jorge
Hope you are well - did you get that London site working on MPLS ?
There is no specific command to make a tunnel bi-directional. It is all done with your crypto map access-lists and your standard interface access-lists if you are using them.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Sun, 04/27/2008 - 22:51
Jorge
Jon
JORGE RODRIGUEZ Mon, 04/28/2008 - 03:15
Hi John, good to see you. hope you are doing well too.
That is what I thought on bidirectional I could not find relevant command but was not sure.
On the London we are still waiting for the circuits to be installed it takes a while, right now the office is vpning in, but going crazy geting the rest of the company cutover into mpls from prn but it is going ok so far.
Best Regards
Jorge
