Inbound UDP 137 traffic keeps appearing
Apr 27th, 2008
I have a ASA 5510 configured with vpn capability. Somehow the vpn client will keep broadcasting the traffic via UDP port 137. Why is this so?
Richard Burts Tue, 04/29/2008 - 04:30
Leonard
Broadcasting on UDP port 137 is a typical Windows networking behavior. Are these VPN clients Windows PCs?
Rick
Richard Burts Tue, 04/29/2008 - 04:46
Leonard
Because if they are Windows PCs then broadcasting on UDP 137 is a normal behavior. Your question suggested that there was something unexpected or unusual. But Windows PCs broadcasting on UDP 137 is quite normal.
Rick
leo_zidane Tue, 04/29/2008 - 04:50
However the ASA 5510 keeps sending me alerts on the VPN clients keep broadcasting the traffic indicating them to be critical alerts. Why is this so?
Richard Burts Tue, 04/29/2008 - 07:20
Leonard
Without knowing how your ASA is set up I could not tell you why it is alerting on this traffic.
Rick
leo_zidane Wed, 04/30/2008 - 04:44
Thanks. I don't remember setting my firewall on this setting. But from your expertise what can the problem be isolated at?
But then my VPN permit client out to the internet after they are authenicated. Cannot be they must keep broadcasting the network with netbios.
