VG224 SCCP and HuntGroup on CCM 6.1
Apr 27th, 2008
Hi all,
i configured a VG224 SCCP gateway on CCM 6.1; all features work fine on analog phone except hunt group. If I configure an analog phone as member of hunt group it doesn't ring. I tried to reset it, to remove and add several times but with no success.
Any ideas?
Thanks in advance,
Overall Rating: 5 (1 ratings)
hanson.stanley Mon, 04/28/2008 - 04:52
I am sorry if i am disturbing you..but im completely stuck with this...Can you help me....????
I am trying to configure a VG224 with a CCME3.3 router.I need call transfer facility from analog phones that r connected to this VG224.I am configuring VG224 as a SCCP gateway.
i have tried to configure sccp in VG224.what i have done in VG224 is ;
#conf t
#sccp local
#sccp ccm identifier 1 version 3.3
#sccp ccm group
#associate ccm 1 priority 1
When i have typed the "#show sccp" command;
this message shows....
"sccp parameters are not activated (dspfarm profiles)or not associated with ccm group"
I have dsp module in CCME router..
then i came to know that dsp farms r to be created and to be associated to the ccm group...
I have gone through the materials..but still i have doubt on integrating...
Can anyone please help me with the detailed configuration??
I am stuck with this..
please please please help me with this....
Thanks in advance.............
DANIEL COHEN-LAROQUE Tue, 11/18/2008 - 13:38
Hello Stefano,
I just face same problem, but with a 2800 IOS using stcapp feature (same as VG224).
By this time, have you found out the problem?
Stefano Amici Tue, 11/18/2008 - 23:12
I'm sorry but I didn't solve the issue; I found a workaround using an ATA to connect that analog phone.
Stefano Mon, 12/01/2008 - 04:37
The VG224 ports are "logged out" of Hunt Groups by default.
If you put a tick in the "Logged into Hunt Group" box at the Device Level on the VG224 that will fix it.
Kind Regards
