WLC 4404 Integration with Microsoft AD
Apr 27th, 2008
I have WLC 4404, WCS & AD. Can WLC be integrated with AD in this situation???
Note: I don't have ACS.
Please suggest.......
ebreniz Mon, 05/05/2008 - 12:40
WLC 4404 Integration with Microsoft AD can work but could you telll me what kind of radius-server are you using for wireless authentication? If the server is Cisco ACS, ACS does check with AD for every authentication (as does the controller); it does not cache the information. You should be able to go into Microsoft to turn on audit trail for successful & failed authentications. If you see AD being hit for every authentication, it would be Microsoft that would be causing the lag.
