Maximum VRF n VFI
Answered Question
Apr 27th, 2008
hello there. what is the maximum VRF n VFI supported on cisco? what is the best selection for PE position? catalyst or Router? tq anyway... :)
Correct Answer by shivlu jain about 8 years 11 months ago
Overall Rating: 4.2 (5 ratings)
mounir.mohamed Mon, 04/28/2008 - 10:55
  • Gold, 750 points or more
A lot of factors could effect your decision
-Number of links will be terminated on
-Amount of Traffic
-Number of customers will be terminated on the PE
-Services will be running on (AToM, TE..etc)
I recommend using Cisco 7200 Series in the PE position for small to mid-range ISP, large-scale ISP can use leadership series 7600.
Best Regards,
Mounir Mohamed
