NAC Authentication in multi Domain scinario
Apr 27th, 2008
HI,
Can anyone guide me how to configure windows authentication & authentication server in multidomain scinario?
Actually I have two domains.Different user roles should be authenticated by different domains.Once the user is authenticated by a domain he should be allocated the particula vlan also.
Can anyone pls guide me?
Thanks in advance
Sachi
gojericho0 Mon, 04/28/2008 - 04:15
  • Bronze, 100 points or more
Sachi,
You would configure a Authentication Server for each domain. You can map a user role based on the authentication server. Users logging into ABC.lcl would belong to the default role ABC users. Users logging into DEF.lcl would belong to the default role DEF users.
You can then tweak the user role policy for each domain.
Here's some documentation if you need help getting started
http://www.cisco.com/en/US/products/ps6128/products_configuration_example09186a0080884229.shtml
sachidananda panda Mon, 04/28/2008 - 04:56
We have already tried this but whenever u try to configure another authentication server it overrides the earlier one.TAC saying its only possible with a single domain. under one domain authentication can be configured with different groups.
