Cisco VPN Client : always same IP allocated
Apr 27th, 2008
I have configured an ISR to allow Cisco VPN Client access, using the local database for extended authentication. My customer wants now to allocate always the same IP address (from the pool addresses) to each user, is it possible, and how is it configurable ?
Thank you by advance,
Patrice
jsivulka Mon, 05/05/2008 - 06:04
  • Bronze, 100 points or more
You can do by configure it in ACS. If the address pool is for the remote vpn client users then make sure that they get the IP's in the same range as the internal network they want to access. Following links may help you
http://www.cisco.com/en/US/docs/security/asa/asa80/getting_started/asa5505/quick/guide/rem_acc.html
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807e0aca.shtml
p.tavan Mon, 05/05/2008 - 06:17
I thank you for your answer,
Best regards,
Patrice
