7200 router xmodem ios upload (urgent)
san_dec21
Hi,all
Pls help me urgentaly.
Can some one explain me how to upload ios image on cisco 7200 router using xmodem or tftp method
Sandeep
I believe that your best option is to use tftpdnld from rommon. tftpdnld will use TFTP to load an image while you are in rommon. To use tftpdnld you first need to set some variables. This describes those variables and how to set them:
usage: tftpdnld [-r]
Use this command for disaster recovery only to recover an image via TFTP.
Monitor variables are used to set up parameters for the transfer.
(Syntax: "VARIABLE_NAME=value" and use "set" to show current variables.)
"ctrl-c" or "break" stops the transfer before flash erase begins.
The following variables are REQUIRED to be set for tftpdnld:
IP_ADDRESS: The IP address for this unit
IP_SUBNET_MASK: The subnet mask for this unit
DEFAULT_GATEWAY: The default gateway for this unit
TFTP_SERVER: The IP address of the server to fetch from
TFTP_FILE: The filename to fetch
The following variables are OPTIONAL:
TFTP_VERBOSE: Print setting. 0=quiet, 1=progress(default), 2=verbose
TFTP_RETRY_COUNT: Retry count for ARP and TFTP (default=7)
TFTP_TIMEOUT: Overall timeout of operation in seconds (default=7200)
TFTP_CHECKSUM: Perform checksum test on image, 0=no, 1=yes (default=1)
FE_SPEED_MODE: 0=10/hdx, 1=10/fdx, 2=100/hdx, 3=100/fdx, 4=Auto(deflt)
Command line options:
-r: do not write flash, load to DRAM only and launch image
rommon 2 > IP_ADDERESS=172.18.44.1
rommon 3 > IP_SUBNET_MASK=255.255.0.0
rommon 4 > DEFAULT_GATEWAY=172.18.44.44
rommon 5 > TFTP_SERVER=172.18.44.44
rommon 6 > TFTP_FILE=c2600-jk2o3s-mz.121-3.T.bin
rommon 7 > tftpdnld
IP_ADDRESS: 172.18.44.1
IP_SUBNET_MASK: 255.255.0.0
DEFAULT_GATEWAY: 172.18.44.44
TFTP_SERVER: 172.18.44.44
TFTP_FILE: c2600-jk2o3s-mz.121-3.T.bin
Invoke this command for disaster recovery only.
WARNING: all existing data in all partitions on flash will be lost!
Do you wish to continue? y/n: [n]: y
Note that setting the variables requires that the variable name be specified in upper case letters.
For additional information you can look at this link:
http://www.cisco.com/en/US/docs/internetworking/troubleshooting/guide/tr1903.html#wp1022683
while it was written for a different platform I believe that the instructions given will work the same on your router.
Rick
Rick
