Catalyst - 6506E - Wont detect WS-X6148A-GE-TX
Answered Question
Apr 28th, 2008
Hi All,
We have Sup 2/MSFC 2 running on the Catalyst and this wont detect the line cards. Please find the show commands below:
console> sh mod
Mod Slot Ports Module-Type Model Sub Status
1 1 2 1000BaseX Supervisor WS-X6K-SUP2-2GE yes ok
15 1 1 Multilayer Switch Feature WS-F6K-MSFC2 no ok
4 4 Unknown Card power-bad
Mod Module-Name Serial-Num
1 SAL0735KN7W
15 SAL0720D8VX
Mod MAC-Address(es) Hw Fw Sw
1 00-06-d6-5d-61-ce to 00-06-d6-5d-61-cf 4.3 7.1(1) 7.6(7)
00-06-d6-5d-61-cc to 00-06-d6-5d-61-cd
00-1d-a1-e6-a3-c0 to 00-1d-a1-e6-a7-bf
15 00-09-12-56-db-40 to 00-09-12-56-db-7f 2.5 12.1(13)E1 12.1(13)E11
4 unknown
Mod Sub-Type Sub-Model Sub-Serial Sub-Hw Sub-Sw
1 L3 Switching Engine II WS-F6K-PFC2 SAL0735KNFZ 3.4
Console>
Console> Sh ver
Console> sh ver
WS-C6506-E Software, Version NmpSW: 7.6(7)
Copyright (c) 1995-2004 by Cisco Systems
NMP S/W compiled on May 6 2004, 23:21:07
System Bootstrap Version: 7.1(1)
System Boot Image File is 'bootflash:cat6000-sup2k8.7-6-7.bin'
System Configuration register is 0x2102
Hardware Version: 1.1 Model: WS-C6506-E Serial #: SAL114031RE
PS2 Module: WS-CAC-3000W Serial #: SNI1147AWBN
Mod Port Model Serial # Versions
1 2 WS-X6K-SUP2-2GE SAL0735KN7W Hw : 4.3
Fw : 7.1(1)
Fw1: 6.1(3)
Sw : 7.6(7)
Sw1: 7.6(7)
WS-F6K-PFC2 SAL0735KNFZ Hw : 3.4
Sw :
Sw :
15 1 WS-F6K-MSFC2 SAL0720D8VX Hw : 2.5
Fw : 12.1(13)E11
Sw : 12.1(13)E11
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 524288K 69795K 192349K 32768K 15098K 17670K 512K 256K 256K
Uptime is 0 day, 0 hour, 4 minutes
Console>
Thanks & Regards
Subra
Correct Answer by Jon Marshall about 9 years 4 weeks ago
Subra
Firstly you don't have an SFM (switch Fabric Module) so all your linecards will share the 32Gbps classic bus.
Secondly the WS-X6148A-GE-TX is positioned as a wiring closet module ie. you probably wouldn't want to be using this module for a server farm. It really depends on what you want to use the switch for.
Not sure what you mean about negative performance. As i say you are limited by the available switch fabric.
What are you intending to use the module for and are you intending to install any other modules and what would these be used for ?
Jon
Overall Rating: 5 (1 ratings)
subra4u Mon, 04/28/2008 - 02:59
Hi Jon,
Thanks for the Input but I am curious about the jumbo Frames support. All we are cocerned about is a regular 1518 byte frame support. What difference will it actually make.
Thanks & Regards
Subra
Jon Marshall Mon, 04/28/2008 - 03:03
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Subra
You've confused me now. What do you mean about jumbo frames support and how is this related to the card not being recognised ?
Jon
subra4u Mon, 04/28/2008 - 03:30
hi jon,
Sorry. May be i am not asking you the right question.
Lets say i upgrade the catos on the switch to support the line card.
The Line card - WS - X6148 A - GE - TX has got the Jumbo frame support but all we will do is a regular frame on this switch.
Will it make any difference using this line card in the switch.
THANKS & REGARDS
SUBRA
Jon Marshall Mon, 04/28/2008 - 03:40
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
If you don't need the jumbo support then it comes down to the question of what other alternative modules you can use.
Do you want PoE and do you want 10/100/1000 interface capability.
Jon
subra4u Mon, 04/28/2008 - 04:07
Hi Jon,
We dont need POE as well. But we are planning to use the same line card in that case do i have any negative impact on the performance or is it any good.
thanks and regards
subra
Correct Answer
Jon Marshall Mon, 04/28/2008 - 04:17
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Subra
Jon
subra4u Mon, 04/28/2008 - 05:08
Thanks for the Input. We are planning to put 2 of the line cards and create vlans for a server farm. No other modules will be installed except for these.
Thanks & regards
Subra
Jon Marshall Mon, 04/28/2008 - 05:22
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Subra
These modules are classic modules so they only connect to the 32Gbps shared bus. So you have 2 x WS-X6148A-GE-TX modules both connecting to the shared 32Gbps bus. So you need to factor this into the equation. For example if you were to fully populate these modules with server you would be very heavily oversubscribed.
It all depends on how many servers you intend to connect and what throughput you need for each server.
It is worth saying again that these modules are not really designed for server farms. If you connect to these servers over a WAN then the WAN speed might be the limiting factor but within a campus environment it may very well not work as you hoped.
Jon
subra4u Mon, 04/28/2008 - 09:12
Hi Jon,
Thanks again. We will have only a Handful of Servers connecting and hence it shouldnt be problem.
Thanks & Regards
Subra
