Cisco 1760 setup
Apr 28th, 2008
Hi, not very good on Cisco kit so please excuse my capabilities. I have attached a simple diagram to help explain what I need, can anyone help as I cannot seem to talk to the outside world
stellastreet Mon, 04/28/2008 - 05:01
show run
Building configuration...: %IP_SNMP-3-SOCKET: can'
Current configuration : 1368 bytes
! Last configuration change at 10:48:30 London Mon Apr 28 2008 by root
rommon 5 >
*Mar 1 00:26:05.675: Un
! NVRAM config last updated at 15:50:32 London Fri Apr 25 2008 by root
rommon 5 >^ 0
version 12.3sukcorprtr1#
service timestamps debug datetime msecy
service timestamps log datetime mseccorprtr1#
no service dhcp
hostname ssukcorprtr1
ip domain name
rommon 7 > dir f
ip name-server 205.x.x.28
ip name-server 205.x.x.28sco Systems, Inc.ce name
ip name-server
ip cef
username root privilege 15 secret xxx
rommon 8 > dir
interface FastEthernet0/0ata-base: 0xrtr1#configtf
description $ETH-LAN$
ip address (revision 0x300) with 29492
ip nat insidef memory.
speed auto
interface Ethernet1/0
description $ETH-
ip nat inside source list 100 interface Ethernet1/0 overload
ip nat inside source static 205.x.x.65
ip classless
ip route
ip http server
ip http authentication local
access-list 100 permit ip any any
snmp-server community public RO
line con 0
line aux 0
line vty 0 4
privilege level 15
password symstor
login local
transport input telnet
line vty 5 15
sntp server 209.x.x.186
Edison Ortiz Mon, 04/28/2008 - 06:36
That output is very cryptic. From the portion I can understand, it seems you have NAT configured and it should work (given you have the default gateway pointing to, which you have).
Are you able to ping from a workstation ?
If both answer are Yes, internet is working and you may be having problem with DNS.
