muzammelhaque Mon, 04/28/2008 - 04:21
Hi Riccardo,
Thanks for the reply. I found the command utility is:
opctest /cust custname /node ICM node name
custname is the instance name ?
nodename is the PG host name ?
can you please give me the live example.
Muzammel
Riccardo Bua Mon, 04/28/2008 - 04:29
  • Cisco Employee,
Hi Muzammel,
Let's say that you want to connect to OPC on Pg1a for instance heroes
Your opctest will look like this:
opctest /cust heroes /node pg1a
The node is the is the PG followed by the number and the side.
Riccardo
Riccardo Bua Mon, 04/28/2008 - 04:42
  • Cisco Employee,
Just to complete the reply, for procmon it will be:
procmon heroes pg1a pim1
muzammelhaque Mon, 04/28/2008 - 04:57
Hi Riccardo,
Thank you very much. Its working now.
But if I run the utility & set the trace/dubug how I will turn off.
Muzammel
Riccardo Bua Mon, 04/28/2008 - 05:02
  • Cisco Employee,
It is in the doc:
When you finish troubleshooting, use the /noall switch in order to turn off all OPC tracing
debug /noall
trace * /off
Riccardo
muzammelhaque Mon, 04/28/2008 - 06:50
Hi Riccardo,
I got the answer. Thank you very much.
Muzammel
