policy-map on tunnel or physical interface?
Answered Question
Apr 28th, 2008
Hi all,
I have a 3800 headend router which has a number of ipsec tunnels to remote office sites. Our current QoS design applies a policy-map to each tunnel interface to prioritise and shape outbound traffic.
My question is how does the physical egress interface queue and transmit traffic from tunnel interfaces with this design? For example, if a mixture of large data packets and voice packets from different tunnel interfaces hit the physical interface around the same time what will happen to the voice packets?
Furthermore, would it be a better to apply the policy-map to the physical interface instead of the tunnel interfaces? What advantages if any would this bring?
Many thanks.
Correct Answer by Joseph W. Doherty about 8 years 8 months ago
If you're shaping each tunnel to the outbound physical bandwidth, yes it would be better to just have the policy, without any shaping, on the physical interface. Again, you'll will either need to depend on a copied ToS value in the outbound packet or use qos pre-classify. (A single physical policy would be much like your QUEUE_DATA if using qos pre-classify.)
e.g.
!assumes qos-preclassify
interface Ethernet0
service-policy output QUEUE_DATA
What I thought you might be doing, and you could also do, was shape each tunnel to the far side's ingress bandwidth. This would require a distinct policy, if the shaper values change, for every tunnel interface, or a policy on the physical interface that has a class per tunnel (matches against tunnel destination address).
e.g.
!assume local outbound interface not oversubscribed
policy-map NESTED_QOS_512K
class class-default
shape average 512000
service-policy QUEUE_DATA
policy-map NESTED_QOS_768K
class class-default
shape average 768000
policy-map NESTED_QOS_1500K
class class-default
shape average 1500000
interface Tunnel1
service-policy output NESTED_QOS_786K
interface Tunnel2
service-policy output NESTED_QOS_512K
interface Tunnel3
service-policy output NESTED_QOS_1500K
interface Tunnel4
e.g.
class-map match-all Tunnel1
match group (ACL that matches tunnel1 destination address)
class-map match-all Tunnel2
match group (ACL that matches tunnel2 destination address)
policy-map outbound_tunnels
class Tunnel1
class Tunnel2
Interface Ethernet 0
service-policy outbound outbound_tunnels
If all the far side bandwidths exceed your local outbound physical bandwidth, then you should have both tunnel policies, that shape each tunnel, and a physical interface policy.
e.g.
!assume local outbound interface is oversubscribed
class class-default
class class-default
class class-default
interface Tunnel1
interface Tunnel2
interface Tunnel3
interface Tunnel4
interface Ethernet0
Overall Rating: 5 (2 ratings)
Joseph W. Doherty Tue, 04/29/2008 - 16:21
Should depend whether your tunnel shapers' oversubscribe the physical interface. If so (i.e. you oversubscribe), then you could get congestion at the physical interface which would be handled by its default queuing for that interface type. If this is the case, you would need a policy on the physical interface to prioritize important tunnel traffic. (This is in addition to the tunnel policy.) Selecting the correct packets to prioritize could be based on the original packet's ToS copied to the tunnel packet's ToS, or via usage of qos pre-classify.
steve_mils Wed, 04/30/2008 - 00:53
Each tunnel uses the same nested policy, shaped to the speed of the physical internet link (10Mbps):
policy-map QUEUE_DATA
class Voice
priority percent 15
class Interactive_Video
priority percent 20
class Call_Signaling
bandwidth percent 4
class Network_Control
bandwidth percent 4
class Critical_Data
bandwidth percent 27
random-detect dscp-based
class Bulk_Data
bandwidth percent 4
class Scavenger
set dscp cs1
class class-default
bandwidth percent 25
class class-default
shape average 10000000
interface Tunnel0
description Remote Site X
interface Tunnel1
description Remote Site Y
interface Tunnel2
description Remote Site Z
Would it be more efficient / effective to apply the policy-map to the physical interface instead of the tunnels?
Correct Answer
Joseph W. Doherty Wed, 04/30/2008 - 03:30
e.g.
interface Ethernet0
e.g.
class class-default
class class-default
class class-default
interface Tunnel1
interface Tunnel2
interface Tunnel3
interface Tunnel4
e.g.
class Tunnel1
class Tunnel2
e.g.
class class-default
class class-default
class class-default
interface Tunnel1
interface Tunnel2
interface Tunnel3
interface Tunnel4
interface Ethernet0
steve_mils Wed, 04/30/2008 - 06:04
The physical egress interface is 10Mbps on the headend and we have remote sites that have 10, 4 and 4Mbps internet links respectively. Based on your feedback it seems that the best approach for the headend would be to have separate tunnel policies which shape at 10, 4 and 4Mbps and then an overall 10Mbps shaping for the physical interface. We'll also use qos pre-classify.
Many thanks!
Joseph W. Doherty Wed, 04/30/2008 - 09:20
You shouldn't need a shaper for your 10 Mbps tunnel or egress interface, i.e. something like this might do:
policy-map NESTED_QOS_4M
class class-default
shape average 4000000
interface Tunnel1
!the physical interface's policy will manage congestion for this tunnel
interface Tunnel2
service-policy output NESTED_QOS_4M
interface Tunnel3
interface Ethernet0
steve_mils Thu, 05/01/2008 - 02:45
I've just found out that the 10Mbps circuit to the provider is a burstable to 40Mbps and is provided over a 100Mbps bearer. Would it therefore be advisable to create a QUEUE_DATA_10M for the 10Mbps tunnel because this could in theory get swamped?
Joseph W. Doherty Thu, 05/01/2008 - 03:33
Assuming your remote sites are physically limited to 10, 4 and 4, yes, if burstable to 40 Mbps and the physical interface can support 100 Mbps or gig. Shape the 10 Mbps tunnel at 10 Mbps. No need to do anything at the physical interface, since both a 100 Mbps physical and 40 Mbps logical can deal with the combined 18 Mbps without the need to queue.
No, if your handoff circuit is truly stuck at 10 Mbps. The physical 10 Mbps at the interface will "shape" both your total traffic and the 10 Mbps tunnel.
