Point Of Sale communcation over Cisco 3640 router with PRI
Apr 28th, 2008
Dears,
I have a Point Of Sale Terminal at the remote side, this POS dialing a PRI and connected to one of the PRI channels at the router, after that this POS needs to send a message to the payment server over specific TCP port for payment authorization, what kind of configuration can be done here please? Appreciate if some one sends me a sample of configuration.
paolo bevilacqua Tue, 04/29/2008 - 08:39
  • Hall of Fame,
    Founding Member
Do you have the modem configuration for the 3640 working already ?
m.salah Tue, 04/29/2008 - 20:11
yes, the modem is MICA type which support analog lines.
paolo bevilacqua Wed, 04/30/2008 - 10:09
  • Hall of Fame,
    Founding Member
Then all you need to do, is to configure "autocommand" under the vty line that does telnet to the server.
m.salah Sun, 05/04/2008 - 01:45
But how the message will be sent to the server, do you have sample of configuration?
Thanks.
paolo bevilacqua Sun, 05/04/2008 - 09:42
  • Hall of Fame,
    Founding Member
The messages are inside the telnet connection. There is no configuration to speack of, just the autocommand telnet.
ricardo-morales Sat, 11/29/2008 - 08:40
hi do you resolved this issue, i am triying to do the same with a AS5350, can you paste de config to try to solve this.,
