Vista IE7 and PDM.
Apr 28th, 2008
Just "upgraded" to Vista and am unable to connect to any PDM v3 firewalls. I believe this issue is to do with SSL2. I have enabled this on IE and also firefox 2 but just get a page can't be displayed. Also enabled SSL via about:config but just says security protocol is not installed.
Anyone know a solution to getting older PDM client to be connected to via IE7 or Firefox?
ebreniz Mon, 05/05/2008 - 06:16
  • Silver, 250 points or more
Looks to be a java plugin issue that I've seen quite a few times. What version of Java is running on these problem clients?
PDM Version 3.0 supports the
Java Plug-In 1.3.1, 1.4.0 and 1.4.1 (recommended) so make sure the clients have a supported Java plugin version.
You could also upgrade to PDM 3.0(4) to get newer java support.
Download the file "pdm-304.bin"
Cisco PIX Security Appliance Software-Download
http://www.cisco.com/cgi-bin/tablebuild.pl/pix
