eBGP Loadbalance with ISP and internal OSPF routing
Apr 28th, 2008
I have the attached network, I need to run ebgp with our ISP and perform load balancing on two 1G link Ethernet connections, how I can do that without looping problems, bear in you mind that our internal routing protocol is OSPF.
Appreciate the expert people support.
smahbub Mon, 05/05/2008 - 08:50
  • Silver, 250 points or more
The BGP Multipath Load Sharing for eBGP and iBGP feature allows you to configure multipath load balancing with both external BGP (eBGP) and internal BGP (iBGP) paths in Border Gateway Protocol (BGP) networks that are configured to use Multiprotocol Label Switching (MPLS) Virtual Private Networks (VPNs).
refer the following URL for more info:
http://www.cisco.com/en/US/docs/ios/12_4/ip_route/configuration/guide/heibmpl.html
