CSA Loopback Interface Characteristics
c01642643287
I have started to get errors in the management interface referring to interface "Loopback\Loopback". When i have created an interface set or the wizard has created a set its changed the second "L" to lowercase e.g. "Loopback\loopback" when i hit save. Does anybody know if this is a bug and if theres a fix?
tsteger1
Level 8
Level 8
Does the interface set not work or is it just changing the case?
I've seen similar behavior with @removeable. No matter what you put, it changes it to a particular case\syntax and no other.
I think it has to do with what the hosts report back to the MC.
You can run a detailed diagnostics on the host to find the local interface charcteristics.
It will probably report the name of the Network Interface Set (Loopback/Loopback) not the value (Loopback/loopback).
Tom
