3030 concentrator crashed with SEP errors.
Apr 28th, 2008
I opened a TAC case and received a replacement SEP module. This 3030 has two SEP modules in it and it seems that the one in slot one is the only one that is ever being used - and that is the one that generated the errors to cause the 3030 to crash.
Are the SEP modules hot-swappable? If not, can I disable the SEP in slot one and have the 3030 use the second SEP in slot 3 - so that I don't have to power down the concentrator?
