ASA Routing EIGRP
Apr 28th, 2008
Can someone tell me if an ASA will support EIGRP or any other routing protocols as a full router. Or is the ASA a stub router. Can you get me some documentation
cdetirado01 Mon, 04/28/2008 - 10:24
Thanks for your information, but can you tell me if EIGRP or OSPF is supported to run across the VPN tunnel and passw routing updates. I currently have two ASA and we are running an IPSEc tunnel as our backup connection in case our metro e connection goes down.
goodwinscottns Fri, 08/01/2008 - 10:31
Could you post a brief summary of your ASA EIGRP configuration? It would be helpful to see the config of your interfaces (ASA side and switch/router side), and EIGRP statements. There are not many ASA-related examples to be found as this is a new capability on the ASA. Thanks!
