Call Fwd to LD number
Apr 28th, 2008
I am having a problem forwarding to an LD number in CCM 4.1.3. This only works when the caller is internal or within the same local area code as the forwarded phone.
Anytime a caller from outside the area code calls in, and is forwarded to the LD number, it gets a message from telco indicating that LD is not assigned to the number.
I have changed my mask to present a local number to this phone and it works fine. I can see the debug that the call is leaving the gateway with the proper digits.
irisrios Mon, 05/05/2008 - 06:21
  • Silver, 250 points or more
If you are configuring a forward number such that you can enter a PIN after a call has been answered remotely. This may be possible, but before we can get it set up, I need to know what kind of gateway you are using to get at the long distance number.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7920/firmware/1_0_9/english/release/notes/rn109.html
Rajesh Revuru Mon, 05/05/2008 - 07:24
You have to have correct CSS for CFWD all.
hauchinango Mon, 05/05/2008 - 07:28
As noted in my initial post....
I have changed my mask to present a local number to this phone and it works fine. ***I can see the debug that the call is leaving the gateway with the proper digits*****
glenn.martindel... Mon, 05/05/2008 - 12:14
Do you have any of the "redirecting number IE Delivery" check boxes checked on your gateways?
glenn.martindel... Mon, 05/05/2008 - 12:29
That may be your problem. Do you need to maintain redirecting number for inbound calls? I think this is typically used for certain VM integrations. If you do not need it, I would recommend unchecking it and restting your gateway. I'm not exactly sure why your LD provider is rejecting the call based on calling number but I suspect this may correct your problem. Let me know how it works out.
Glenn
hauchinango Thu, 05/15/2008 - 06:18
I unchecked this and the problem remains. Basically, the area code the IP phone resides in is xxx.
The phone I am calling from is area code phone number yyy-555-1111
So phone yyy calls xxx, and in the debug on xxx's gateway, the calling party number is displayed as yyy-555-1111. I suspect since this number is with another carrier, it is being rejected. I recently switched carriers and this started after I switched.
