Restart Skip
Apr 28th, 2008
Can someone tell me exactly what this means and if it is a common error, is there a way to tune it so it does not fill up the logs or syslog servers?
Dwane
56603 04/28/2008 11:15:43.490 SEV=6 AUTH/95 RPT=20383
Restart skip(11845740/12)Server name = xxx.xxx.xxx.xxx.xxx, type = RADIUS,
use = Auth(48545541), status = Active(1)
p-dolbow Mon, 08/04/2008 - 07:33
Dwane,
I am having the same problem - did you ever get an answer to this?
Phil D.
Alex Pfeil Fri, 08/22/2008 - 05:54
We are currently having an issue with the vpn going down at random times. I have noticed this exact event in our log as well.
Did either of you find a fix?
pmlund Wed, 03/17/2010 - 08:28
We're experiencing the exact same problem.  I notice that this is an unanswered question from a very long time ago.  Does anyone have an
answer as to what causes this?
Thanks!
stuart.jones Tue, 10/26/2010 - 11:50
All,
Same here, did anyone make any progress with this, would appreciate a nudge in the right direction.
Stuart
