qos trust cos or qos trust dscp?
My core switches are a pair Cisco catalyst 4006s with a sup 4 module. The questions are:
1. Should I use qos trust cos or qos trust dscp when setting up qos on a per port basis?
2. Which is preferred?
3. I have a cos to dscp mapping so does it really matter?
Any help is greatly appreciated. I just want to make sure that I'm honoring all tags.
Mark
furionsky333 Thu, 10/10/2013 - 01:35
why ? I can't input command "mls qos trust dscp", instead of only input "qos trust dscp".
what difference between this two command?
thanks a lot
islam.kamal Thu, 10/10/2013 - 10:06
  • Red, 2250 points or more
They are the same commands , the only difeerence the IOS supported commands. You will find also to trust cos instead of  mls qos trus cos . You also have to use auto qos default instead of auto qos voip trust.
Thank you
please rate all useful information
